I've been shooting on DSLR for a little over a year and a half now. It's been awesome, but one of the issues that always crops up is getting decent audio. I started out using mics that plugged directly into camera and then graduated to using dual system sound with higher end mics.
Because the work that I do usually requires fairly quick turnaround, I only use the second system for interviews and other "mission-critical" audio, b-roll and ambient stuff uses the in camera mics. I'd like to keep my streamlined workflow, but get better quality audio all the time. So, I took the 40 dollar plunge and bought a Sescom 25dbV pad w/ headphone jack online so that during the shots I would normally stick to the internal mics, I can feed in the good quality audio instead. I'm still planning on using dual system for interviews because the quality on the recorder is definitely better than my camera's input.
I started thinking about the easiest way to calibrate my recorder's audio levels and I think I might have overcomplicated things in my head. I also talked to our tech guy at work which just made me think of more questions.
So, what's the easiest way to match up the levels I see on the recorder with what I'm getting in camera? I have a Nikon d7000 with no audio meters, just low, med, high, and auto settings.
Also, if there's a better audio solution, let me know. I'm saving my pennies for a newer camera w/ headphone monitoring and more manual control, but the 7000 still gets the job done so I'm not in a hurry to upgrade.
