guidedbygbv
Can't wait to see one mounted.
He already reviewed the 1/2" relay with the EX3. Wouldn't be the same thing?
2700 US dollar, very expensive isn't it?
Two very different systems. If I own a HPX300 I would want to see what kind of images that relay coupled with an Elite/Ultimate and Nikons, for example, would produce. The review of the 1/2" relay and the EX3 does nothing to help with my purchase decision.
Compared to what? It's the "cheapest" relay unit they make.
I too am also interested in the Letus relay. One thing that is not clear - does this require the relay, and a Letus adapter together (such as the Letus extreme)?
Yes. You will need an adapter to go with the relay. It may seem like you're putting lots of components between your lens and your sensor but I like this way better than an HVX/HPX using the stock lens to shoot an image on the ground-glass of a adapter. Don't get me wrong, I like the look of the HVX/Letus combo but by bypassing the "stock lens" and recording straight on to the sensor, you must be able to gain/retain a bit more resolution instead of losing resolution.
Just my theory anyways :smile:
The relay is somehow "projecting" an image onto the sensor is it not? So you're recording straight to the sensor from the relay are you not?
I'd sooner rent (or buy) the right camera in the first place, rather than blow that kind of money on an adapter for a 1/3" camera.
Can you use the Letus 1/3" relay with your current Redrock system?
Why not? Get an HPX300 and paired it up with one of these and you can have a fully functional high quality cinema style camera for around $15k. Whereas if you go for something like the RED or 2/3'' + relay you're talking many times that amount. I can see something like this working great with a real broadcast style camera with little compromise in quality.
