Less Expensive Shoulder Mount Alternative
ChuckS
There are several threads on different sites discussing various camera supports, everything from DIY, RedRock Micro, to Zacuto, After looking at all of these I decided I couldn't/wouldn't spend more for the support than I did for the camera. I also knew I was not going to build one myself from scratch.
So I went in search of alternatives which I have shared in the several posts.
I decided to take pictures of my setup so people could see what it is and how it works. What I discovered is that I'm not very good at photographing products but here it is nonetheless.
http://www.frameyourart.net/7D2.jpg -- I don't know how to embed the image into this post?
This is a shoulder mount system which includes an accessories box, an adjustable back support, a counter wait (not shown), two hand grips, a telescopic support arm (not attached in picture), a CAVISION LCD swing away viewfinder, 15mm Carbon fiber support rods with quick release, and a 4x5 Matte box.
I have placed the accessories box under the camera to give it some additional height but it can also be attached on the back shoulder pad. The camera support can be adjusted to accommodate a larger camera like the EX1, the handles can be adjusted with the push of a button and the telescopic support arm is spring loaded and can be adjusted to rest comfortably on your stomach or waist. As an alternative to that you can attach the counter weight to the back pad and the 7D requires very little support.
Not only is there a substantial price difference between this setup and a Zacuto for example, but there's probably a bit of an ideological difference too. The aforementioned products are more configurable in the way a photographer might want to use it, this set up is probably what videographers are more accustomed to.
So I don't think choosing the right camera support is simply about price, although this setup is less then half the cost of a comparable set up from from Zacuto or RedRock, but about how you want to work. Clearly the 7D would benefit from either type of solution, and as you can tell I've approached it from more of a digital cinema perspective, which I'm not sure is the right approach. It works incredibly well in a production environment but it "hinders" the "gorilla" aspect of shooting with the 7D. I find myself detaching the camera from the support, removing the matte box (if I don't need filters) and holding the camera by the support rods. People don't pay attention to that and think I'm taking stills.
Since I've chosen this route the next thing is a follow focus, but I'm not going to pay $1200...
Anyway for others who are experimenting and looking for ideas I hope this helps.
So, where do we look at this setup closer and buy one? I have spent 3 days trying to get a good support for my 7D. Thanks for sharing.
Hey ChuckS! VERY NICE INDEED! I agree with your perspective too....I don't care to pay 1200 for a follow-focus either.
So...can we get a product list? Maybe some weblinks? Thanks again!
No worries.
The shoulder mount is from Shape and there are several models to choose from:
http://shapewlb.com/en/products-camera-supports.php
I have the Spider II, which has an adjustable camera platform. This is important for me because I also use this support with the EX1. If you don't need that then you save even more.
The LCD viewfinder is here:
http://www.cavision.com/viewfinders/MHE52.htm
The swing away support for the viewfinder is here:
http://www.cavision.com/viewfinders/MHE52C2SA.htm
The Rod Support and Quick Release is here:
http://www.cavision.com/rods/RS15IIMQR.htm
The Matte Box is here:
http://cgi.ebay.com/PROAIM-Matte-bo...ltDomain_0?hash=item1c0e60a4e8#ht_4258wt_1027
OK, this one requires a little explanation. I got this off of eBay, its a knockoff from India and it was so cheap, $240 that I thought I would take a chance on it. Out of everything that I ordered, it arrived first, the build quality is surprisingly good and it bolted up to everything else perfectly.
I think everything totaled around $900. Still a bit pricey, but so far I'm happy with everything I purchased and this would have costs significantly more elsewhere.
I'm not trying to talk anyone in or out of anything, just trying to provide some choice.
