Lens for itraoral shot
a7sharp9
I need help finding a lens for dental work. I want to get as tight a shot as possible. I have the Panasonic 100-300 but the minimum distance was too long to get the shot I wanted. I am hoping I don't have to use a GH2 with it's 1x1 pixel extender feature (not sure of proper name) because we often switch live and I would have to ditch the GH2 in that scenario.
Any help would be appreciated. Thanks!
I have a pentax 55 mm macro lens with a pentax to M43 adapter. something like that and a LED light source might work
We are working in a multi-cam situation with medium shots so I wouldn't wouldn't be able to be that close to the patient. So, I think I just need a longer lens than the 100-300. Or a similar lens with a shorter minimum distance. The 100-300 is 4.9 feet.
The voigtlander has a super close minimum focal distance so could be an option but it's only a 25mm, but with the teleconverter you are probably good...
You probably would need to get something like an 85mm macro but then you really would have to be a great distance away to get medium shots.... This might prove to be tricky...
You can get a screw-in close-focus diopter lens that will change your minimum focus distance; try that, it might get you what you need with the equipment you already have.
I'd recommend the sigma macro lenses. Just choose the one with the working distance you need. they are all 1:1 macros ie they will give you the same magnification.
i use the 105 on my af all the time.
sigma 105 11 inches
sigma 150 15 inches
sigma 180 18 inches
I am heading over to Abel Cine to purchase one for my shoot this afternoon. Exactly what I needed! And much more affordable than the road I was headed down... Thanks for all the suggestions
