This was a very useful lesson for me.
I've always assumed that a darker scene such as this, if shot with a digital camera, was lit brighter and then toned down in post so that the noise level is better controlled. Is this the case or no? I'm not talking about day-for-night. Just scenes like this where it seems the noise level would benefit from a brigher set.
alot of awesome advice, but for the sake of throughness, ultimately you decide what cinematic is.
Here's a chart:
Naturalism---------------Realism---------Expressionism
Nestor Almendros------Hollywood------John Alton
Take ideas from all three.
I think a big mistake alot of zero-budgeters make is try too hard to do a hollywood style with no hollywood money.
How did you get the background to look like that? Also could you describe the process of lighting that particular background with different temp?I would light background with different temp so its not mono/orange so much after color correction *You need to reframe this, too much table is visible, then maybe add rim light on dark side of your head, fix some light high behind you and experiment a lot![]()
Add a soft diffused light source (flagged appropriately off the foreground) of cooler colour temperature (either by gels or kelvin controls in camera along with type of bulbs used.).Also could you describe the process of lighting that particular background with different temp?
I'm trying to learn here. What approximate Kelvin value woud you set in camera to get this color asuming he's using tungsten lights?Wouldn't the whole scene to blue and not just the background?If it was to be done using gels, which gel would you use?Add a soft diffused light source (flagged appropriately off the foreground) of cooler colour temperature (either by gels or kelvin controls in camera along with type of bulbs used.).
