Curnsie
I purchased the LCDVF as it seemed to be getting more or less the same positive feedback as the Hoodman Loupe. It was also in my price range.
Attaching it to the camera (550d in my case) is relatively easy, although its obviously been designed for the 4:3 LCD of the 7D or 5Dmk2, as the metal frame is not the correct shape for the wider aspect 550d LCD. That said it does not cover the picture in any way. The metal frame comes with an adhesive surface which bonds to the back of the camera (more said about that later) and the LCDVF loupe is attached to this magnetically. Focusing is made easier, but where it shows greatest benefit is when shooting outside or in sunlight. I can no judge exposure more accurately. It also provides a stability when shooting handheld. The magnification does show the pixels on the LCD, meaning focusing is still a little tricky until I get used to it.
As I mentioned above, the metal frame is bonded to the back of the camera. The adhesive comes already applied. You simply remove a paper cover. I've only had the LCDVF for 2 days, and have only run some 'minor' tests. To my great annoyance the metal frame has fallen off twice. The first time I was removing the loupe which also removed the metal frame. The second time I simply lifted the camera with the loupe attached and the loupe plus metal frame fell off!! The adhesive used is not strong enough. That combined with the fairly powerful magnets mean that the metal frame is prone to coming off.
I'm not sure what the solution is. I've read that elastic band method of the Hoodman has its problems with the 550d body. I'm aware that RedRock Micro produce a device for attaching the Hoodman, but does anybody know if it will work with the LCDVF. Is anyone else experiencing this problem?
