C100: LCD color not true?
Hi everyone,
Can I check if anyone has an issue with the c100 LCD monitor in terms of color? The problem here is that my C100, the color on my editing monitor and the color on the LCD are different. When it was white balanced, the C100 LCD looks pretty neutral while the editing monitor was a little yellow. We have no issues with the editing monitor for previous projects. We check the calibration on the monitor again. I have checked back and forth with the internal color bar of the C100 and calibrated accordingly and it looks different in terms of white balancing. Anyone has the same issue?
Mine has a blue cast.
Hi everyone,
My LCD has a blue cast.
yup, thats why they have a function that lets you to calibrate your LCD
its not a very professional way of doing it but ....
mine has a magenta cast
You can calibrate the LCD, but not shift the color tint, only bright/contrast/ more or less color - not actually shift the color - which I wish I could do, because the LCD has made me not trust the white balance settings, since it always has a off-cast to it, and I don't always have my external monitor hooked up to it.
