KevinScott
I attended the Los Angeles FCP User Group meeting last night, and Panasonic was there with another prototype HVX-200 (non-functioning) on display. The main topic was P2 Workflow, which applies equally to other camcorders that accept P2 cards like the SPX-800. No other HD cameras were mentioned by Panasonic.
Something I haven't heard before was that another PCMCIA-form factor slot will be included on "full size P2 camcorders" for the purpose of recording a compressed MPEG-4 Proxy video of the SAME content that is simultaneously recorded to the P2 card(s). The user has a choice of three bitrates:
1. 196 kps
2. 768 kbs
3. 1.5 Mbps
The two main purposes (mentioned by Panasonic) of this proxy video is for "content approval", "Dailies".
Of course, the other natural use might be for use in an "off-line edit" of HD video, so I asked the Rep if Timecode Data was also recorded to this PCMCIA-slot card. The Rep stated that they are working to add this functionality right now... the difficulty is dealing with long-GOP MPEG video stream where the only "real" frames are I-frames and B-frames; they (Panasonic) have not yet found a way to add Timecode due to P-frames being random (by nature).
Panasonic also stated that this new PCMCIA-slot accepted a different type of card than a P2 card; and, that they were also working on a device that would drop in to this slot and transmit the MPEG-4 proxy video to a receiver (think 802.11b/g).
The only other bit of news is that Meta data recorded in the XML file structure to P2 cards is saved with the audio & video content ...when imported into FCP 5 using the File/Panasonic P2 Import command. This data can be used for search purposes; –i.e. contains Clip Duration, Clip In/Out points, Picture of first frame in each clip, Voice Annotations, etc.
To archive your work, Panasonic mentioned saving your content to LTO or SAIT tape, to Blue Ray Disc, or to a Holographic disc from a company named "InPhase". They did not show any archiving devices; they only mentioned them in a pretty lame PowerPoint presentation.
FWIW
Kevin
1. 196 kps
2. 768 kbs
3. 1.5 Mbps
FWIW
Kevin
