paulcurtis
I wonder what the deal is going to be with this combination and the next firmware.
I'm running a 2470z with LA-E2 on both a NEX5 (which gives full support) and on the FS as a dumb adapter. On the FS the aperture is wide open so f2.8 and can't be changed yet.
I've not reached a conclusion about this combination. The translucent mirror really does cut down the light by at least 1/3 of a stop and perhaps a 1/2 stop. Obviously there would be internal absorption but the light coming out of the 2470z is comparable to an old CZ 2870 f3.5, pretty much the same - which is half a stop difference for what is probably a similar zeiss designed zoom. Whist the FS is sensitive enough to get around this, there's a question of why bother with an expensive f2.8 zoom when a cheaper one will have the same end result.
It's unclear what the LA-E2 adapter will allow for in terms of focusing on the FS. There is talk of a f3.5 limit but i don't understand how that is going to work. On the Nex 5 i can focus at 2.8 no problem. So what's with the f3.5 restriction...?
The focus ring on the 2470z is nice, there are some light stops at each end, not hard but tell you when you hit minimum and infinity. The focus is fly by wire and funnily enough you can see that on the recordings - the focus movement is damped, electronic looking.
I'd imagined that a set of zeiss ZA zooms would make for a nice range but i'm not sold on this yet. The light loss is an issue i feel, why pay £$ for a f2.8 zoom when the f3.5 zoom is really not that different. Continuous autofocus is unlikely to work in real situations, so we're looking at one touch focus being useful - but the manual focus ring on a real MF lens works better, even though as far as MF goes the 2470z is pretty usable.
I don't find the image quality of that 2470z that spectacular either, quite soft in the corners even on APS-C, i was hoping for more at this price. I found the Canon 1755 f2.8 to be better in the same kind of situations. Perhaps i have a bad sample but i've seen reviews online that concur.
What do others think? Does the LA-E1 adapter work better perhaps? I understand that changing iris is not smooth but there's no mirror in there.
Perhaps simple old school manual lenses are best after all.
thoughts would be most appreciated!
Paul
Paul
