Lenilenapi
Carbonite Member
[TD="bgcolor: #f5f5ff"][/TD]
[TD="bgcolor: #f5f5ff"] Posted this last night on DVINfo.net with no responces yet so I'm going here as well.:
I just had a weird issue with a KiPro today. Input would be appreciated:
I was shooting a green screen corporate address to camera at 1080/29.97P. We double recorded to the SxS card and a Ki Pro (not mini). It was just a 10 minute shot but the tech could see the KiPro take numbers changing every minute or so at different intervals throughout the shot. The CEO was a very tempermental guy so we didn't stop especially as we knew we had SxS back-up.
Turns out the KiPro recorded about a dozen little files numbered sequentially "Clip1TK1.mov" , "Clip1TK2.mov" etc. The size varied from 300MB to about 3 Gigs randomly. When I tried to stitch the takes together in Final Cut Pro there seemed to be short gaps between the shots. In other words we were completely hosed!
Fortunately the SxS card is fine and the key will I'm sure cut fine as the guy has not a flyaway hair on the loose. However we don't know what went wrong. The Ki-Pro appeared to be set up correctly and the tech was experienced and knew the KiPro. Moreover when we got back to the shop we tried to replicate the problem and we couldn't. That's actually the scariest part.
Some other details : The camera was connected to and controlled by the standard Sony paintbox (forget the number). Time code was on Record Run The SDI for the KiPro was coming from A output on top and the SDI Out was feeding a monitor. Dual Link was set to 1.5 YPbPr422 & Video SDI Record Control was switched HD SDI Remote I/F (This turned out to be irrelevant to controlling the recorder since it was set to start from timecode anyway) The "Rec 2" note was flashing on the screen as I think its supposed to when the HD SDI Remote I/F is on.
We thought maybe the HD SDI Remote I/F was the problem but when we turned it OFF while still at the location the recorder still broke up into little files.
When we got back to the shop we could not get the reorder to do it again regardless of whether we had the SDI Record Control engaged or not and regardless of whether the cameras time code was free-run or record run and whether the KiPro was set to start from time code or not.
Any ideas? The hard drive did look a little odd - almost as if it could be pried apart very easily. [/TD]
[/TD]
