slimjimmed
Kholi's order for manual lenses in section three of the beginning of the sticky thread:
1. Without engaging LV mode, set the camera in Manual Mode.
....2. Turn on AE-L (hold), you can check to see if it's active by peerin' into the viewfinder for the AE-L icon.
....3. Close your Iris down to an f5.6 ~ 8
....4. Aim the camera at a wall or surface that's brightly lit. It should not be blown out, but bright. ....I would say just about sixty-percent (60%) Exposed or a little more.
....5. Activate LV mode.
....6. Open the Iris to a 2.8 or 1.4 and check the cleanliness. Not to mention the 1/30 ~ 1/60th shutter. Mmmmm. Delightful.
Then on post #79:
You can't lock anything before you go into Live View mode... Anything you've done, for a split second, even if you lock it before hand, is erased prior to entering.
But in your original instructions you say that you lock before live mode. Step 2 is lock and step 5 is activate lv mode. Which is wrong, right?
Post #79 is right. In order to get low noise I have been activating LV mode and then locking immediately after.
Am I wrong? Don't the 2 posts contradict eachother?
Then on post #79:
