Jag35 DSLR Baseplate revisited
We had a thread going for a while regarding Jag35 - I purchased their baseplate and found it was really wobbly - having your gear cantilever out on the rods was really unstable. Thing is, it's a decent idea - if you've used a videocamera rail system, you can't get a follow focus to work with stubby primes. It's something like $140.00, so you can really save some cash over Zacuto or RedRock.
After a long runaround of getting them to ship the right part (they sent me every other piece of the system across a few weeks) I finally got a 2nd tripod-to-rails clamp to steady things up. (They did respond quickly and didn't charge me for parts).
The screw positions on the tripod plate have changed since I purchased mine, so I got out the taps & drills. In the photo below, you'll see two risers from the tripod - the stock unit comes with only one. Bad idea.
Above you can see it with two risers from the tripod plate - this killed the wobble and the rails don't droop towards the front like the stock model. (Note the battery hanging down - more on this below).
Above is another angle - you can see where I chopped a corner off - now I can swap batteries without removing the camera. "Adding" this feature alone is huge for me.
Here's another angle on the cut-off plate - this makes a huge difference, and I wonder if there's a cutout size that would accommodate any popular camera without a battery grip?
Honestly, the whole stacked-risers thing seems like a design dead-end; a solid rail block with about 2" of rod coverage, with a solid block for the camera seems like it would be sturdier. There's no reason to have the camera that high (that I can think of), it just raises the center of gravity. But, for the money, this will see me through for a while.
Glad you finally got the right parts! Personally, I'd like to see more of these risers on the camera plate, and which DSLR are you shooting with?
The right parts and then some - I now have two camera risers, a camera plate, and a rails riser (which is 3mm shorter). I'm shooting primarily with a 550D.
The weakest link on this thing is now the skinny camera riser - like I said, I feel it's a dead-end design, Jag's trying to make easy to extrude parts that can be used for various rigs.
Still, it's awesome for changing batteries! With video cameras' rear-mounted batteries being a long-time standard, nobody seems to have addressed the DSLR battery door.
I did send them the diagram below - a 2" or so rails plate (most video systems have 3 - 5" of Rail clamp opening), with a solid camera block bolted on - add a RedRock style camera screw, and perhaps sell some shims to raise the block? Seems like this would be way sturdier, and much simpler too.
