falconking
Hello.
I´m doing some test for an upcoming film project we plan to shoot with 3 xh a1´s and blow to 35 mm for teathers. I´m recording at 24f 1080p and then capturing the video in cineform HDlink in .mov clips using the film scan quality setup, Frame format progresive, no rate change and keep source aspect ratio on. Then I´m loading this into premiere pro cs2 using the cineform prospect HD -custom- preset at 23.97 fps and 1440 x 1080 1.333 ratio. Once I load the mov clip, I can see that premiere recognizes the clip as 23.97 fps progresive video and everything looks ok. But then I have the first issue: If I press the space bar or the play button in the program window, there is no play back of the clip. Second, I can see in the program window that the video is interlaced. If I zoom in the video the interlacing becomes very clear. The field options in the timeline are set to NONE. and the frame blend set to ON. What I am doing wrong ? I tougth I would get progresive video, but it doesn´t seems to be the case. Any help would be very appreciated. Thanks and forgive my english.
