ahalpert
Major Contributor
S-Cinetone appears to be more clever than I first imagined, it has a great highlight roll-off, and seems ideal for low-mid dynamic range cinematic shooting where 10 bit Slog3 would yield a super thin waveform and fragility in grading. I have a PP with S-Cinetone gamma and rec709 gamut which is great for low light and is absolutely bullet proof in grading. Sony claim the S-Cinetone gamma dynamic range is 460%.
This is essentially what I do whenever the client requests a non-slog3 profile for quick color correction, except I use different specific settings. But the approach is the same - a relatively low-contrast gamma paired with accurate and saturated color out of the box. (I rarely ever blow out my color channels anyway - reflective neon vests and DJ party lights are the exceptions, perhaps? And i have a less saturated profile ready for those. I understand that when I'm using color gamut that's ready out of the box, I'm probably missing out on some hues that a wider gamut would require, but I believe those to be outliers? Most of the colors I capture, most importantly skin tones, look spot on this way.) And then the colorist need only tweak the contrast and they're there.
But I would add that slog3 doesn't look that noisy to me after the standard LUT is applied, even when you don't ETTR and whether I'm using all-intra h264 or long-gop h265 as long they're 10-bit.
