Is the CION ever going to ship?
DLD,
AJA does have a marketing department that creates all of the marketing materials associated with our products: website, brochures, press releases, tweets, Facebook posts, etc. They also organize all of our trade shows and events worldwide. I simply participate here (and on some other forums) because I think it is valuable to directly engage in product discussions, obtain feedback and offer advice or clarification as needed about the products.
Thanks,
Jon Thorn
Senior Product Manager
AJA Video Systems, Inc.
Leteeci,
The raw output allows you the freedom to craft the image in post. The raw output does not have any gamma or color correction applied so those choices may be made in post as opposed to in camera. The pitfall of raw is that you must perform image manipulation in post and this may be too time consuming for some workflows.
I hope this is helpful,
Jon Thorn
It seems to me that for both raw and 'baked' one needs to allow the operator to build/choose a look, and pass that as the 'default' down the post chain - but to compress the DR of the camera to that look seems a little odd as it allows little manoeuvre in post to a) correct exposure b) find a different look. Also some shots 'require' post aka darkening the sky or whatever..
DLD,
Thanks,
Jon Thorn
I was being slightly facetious. Sorry if it was taken without a proper tongue in cheek, Jon.
That said, participating in online forums and the various e-store comment sections should be a part of someone's job. I am actually surprised that so few major brand marketing managers are doing this. I recall frequenting a different site when the Arri 6K 65mm camera was announced and, within the same day, a lady from Arri made several posts to clear several minor misunderstandings. And it wasn't even a site with a heavy Arri user base. More like a DSLR crowd.
AJA CION Quick Start Guide Released
10 Helpful Hints To Get You Started Shooting with CION
https://www.aja.com/assets/support/files/2978/en/AJA_CION_10_Helpful_Hints_v1.0.pdf
Thank you for purchasing the CION production camera from AJA. These notes provide a simple introduction to setting up your camera for the first time. We strongly recommend that you expand your knowledge of CION by reading the full CION manual found online at www.aja.com/cion.
When you first power up CION, the camera is factory set to 4K (4096x2160), the frame rate is set to 23.98 fps, the exposure index (EI) is set to 320, the color correction is set to Normal and the white balance (WB) is set to 3200K. Altering these settings to suit your shooting environment is the key
to creating desirable images with CION.
STAGE 1
Determine what format is appropriate for your project.
The format selection is found in the FPS menu > 23.1 Format.
CION offers the following resolution selections:
• 4K (4096x2160) • Ultra HD (3840x2160)
• 2K (2048x1080) • HD (1920x1080)
STAGE 2
Select the frame rate that is appropriate for your project.
The frame rate selection is found in the FPS menu > 23.2 Frame Rate.
• Typically, cinematic projects will be 23.98, 24 or 25 fps.
• Sports or high motion projects may benefit from higher frame rates such as 50, 59.94 or 60 fps.
Note that with higher frame rate selections, more light will be needed to produce a proper exposure compared to
the lower frame rates.
STAGE 3
Select the exposure index value (EI) that best suits your needs.
The exposure index value is found in the EI menu > 24.1 EI.
• EI 320 is best for outdoor shooting or when working with controlled lighting.
• EI 500 is a good choice when working with controlled lighting.
• EI 800 is useful in lower light conditions.
• EI 1000 is useful when you might not have any control over lighting and must work under only available light.
With any of the exposure index values, you will want to be sure that you have sufficient light to produce a proper exposure.
STAGE 4
Select the shutter angle (or shutter speed) that is appropriate for your subject matter.
The shutter angle (or shutter speed) is found in the EI menu > 24.3 Shutter Speed (or Shutter Angle).
• For most subject matter, the use of a 180 degree shutter is appropriate.
• You can use the shutter selection to produce motion effects (higher or lower levels of motion blur).
• Keeping in mind that the shutter value selection will impact the reproduction of motion, the shutter value
may also be used as a method to control the exposure.
STAGE 5
Select the gamma that will best suit your project needs.
The gamma selection is found in the EI menu > 24.7 Gamma.
CION offers a variety of gamma selections. Typically, you will want to choose from the Normal, Normal Expanded and the Video gamma selections.
• The Normal gamma selection produces very deep blacks and very rich colors.
• The Normal Expanded gamma selection produces deep blacks and rich colors.
• The Video gamma selection produces blacks and colors more commonly associated with traditional video cameras.
• The Disabled gamma selection applies no gamma curve to the image; the image will appear very dark, nearly black. This gamma selection assumes you will post-process the image to produce a desired result.
• The Expanded 1 gamma selection expands the gamma curve resulting in wider dynamic range, but this selection assumes that you will post-process the image to produce a desired result. The gamma selection plays an important role in determining the “look” of your footage and experimentation with the various settings offered prior to shooting a project is strongly encouraged.
STAGE 6
Select the white balance that is appropriate for the scene.
The white balance selection is found in the WB menu > 25.1 White Balance.
• The 3200K white balance selection is suitable for shooting under tungsten lighting.
• The 4500K white balance selection is suitable for shooting under mixed lighting
or fluorescent lighting.
• The 5600K white balance selection is suitable for shooting in open daylight or under daylight balanced lighting.
• Auto White Balance (AWB) - You can use a white card that fills the frame and is not overexposed to produce an appropriate white balance under lighting that doesn’t match the provided presets. Be sure that if you auto white balance that you do not overexpose the white card nor include items in the frame other than the white card you are using to balance.
STAGE 7
Select the color correction that you feel is appropriate for
the scene.
The color correction selection is found in the WB menu > 25.4 Color Correction.
CION offers a number of color correction selections.
• The Normal selection may be used throughout the majority of gamma and white balance combinations. Note that the Normal selection favors skin tones as opposed to overall color accuracy. Also note that this “look” may vary considerably depending upon the corresponding gamma selection used. The Normal selection produces saturated colors.
• The Flat selection disables the in-camera color correction matrix. Images produced with this setting may require additional color correction in post-production. The Flat selection produces desaturated colors with a warm cast.
• The Skin Tones selection may be used to produce less saturated skin tone values when compared to the Normal color correction selection. When compared to the Normal color correction selection, an overall desaturation of colors occurs.
• The Video selection may be used to produce color values more typically associated with traditional video cameras. The color correction plays an important role in determining the “look” of your footage and experimentation prior to shooting a project is strongly encouraged.
STAGE 8
Select the encoding method that is appropriate for
your project.
The encode type is found in the MEDIA menu > 14.1 Encode Type.
CION may be used for encoding Apple ProRes QuickTime files to on-board AJA Pak media.
• Apple ProRes 444 (up to 4K 30 fps)
• Apple ProRes 422 (HQ) (up to 4K 30 fps)
• Apple ProRes 422 (up to 4K 60 fps)
• Apple ProRes 422 (LT) (up to 4K 60 fps)
• Apple ProRes 422 (Proxy) (up to 4K 60 fps)
CION also offers Raw recording to off-board media via Thunderbolt
(up to 4K 30 fps) or via SDI (up to 4K 120 fps).
Note that you can only simultaneously encode Apple ProRes and Raw when Thunderbolt is used for the Raw transport. If the SDI Raw output is selected, you cannot encode to Apple ProRes to the on-board Pak media. For details about Raw encoding, review the CION manual and the AJA CamXchange software manual.
STAGE 9
Use the histogram feature to help determine the
desired exposure for your scene.
The histogram is found in the CONFIG menu > 1.98 Histogram.
(Note that you will also need to enable the Super Out to see the histogram displayed on your EVF or monitor.
The super out feature is found in the CONFIG menu > 1.9 Super Out. You may also find it valuable to enable the 1.92 Super Displayed option as well which will give you information about the camera configuration on the super out.)
As a general rule, you will typically want to expose the image to the point where the brightest object (which you want to retain detail in) falls just below the clipping point; adjust the iris on your lens accordingly to produce the desired exposure. You will know that the signal is clipping when you see the right hand side of the histogram produce a straight vertical line. (Specular highlights and bright lights - like the sun or car headlights in a scene which are grossly overexposed when compared to the rest of the scene - aren’t typically something you will want to expose for; these items will clip in a normally exposed scene.)
STAGE 10
Use the histogram mode to determine if your white balance is appropriate or desirable for your scene.
The histogram mode is found in the CONFIG menu > 1.99 Histogram Mode.
If you set the Histogram Mode to display RGB+Luma you can see not only the overall luminance of your scene, but also the balance of colors in your scene. If you begin to overexpose the scene and the R, G and B values don’t seem to clip at the same rate, then your white balance might not produce white in overexposure, but instead a color cast.
