is half of hv20 in 1080i60 a progressive 540p clip?
Nik Manning
Okay I am trying to get the best slow mo video out of my HV20 I can get. I will finish my projects at 720p. I am thinking would I get a progressive image if I only used 1 field of the 1080i signal. Is that correct? I plan on slowing it down to about 25% of that to get 240 frames per second. Something like this but obviously not that slow.
http://sixex.com/nymphs.mov
I will be using final cut pros new optical flow and 60i to try this. Thanks all.
Of course you can discard one of the fields and line double but you will never get 720p but rather 540p which of course can be upconverted to 720p but this will generate scaling artifacts that will damage picture quality. With one field discarded you will end up with 30 frames per second which can be slow motioned to 24p. What gets me is that most people refuse to buy a 720p camcorder which would be excellent for slow motion because it generates 60 full progressive frames per second. The excuse is that most people think that 720p is not real high definition.
As far as I know there are no consumer grade camcorders in the same price range as HV20/30 that has the capability of 720/60p. Also a lot of people use HV20/30 for 24p.
Three 720p60 consumer camcorders exist. The Samsung HMX-10 The Sanyo HD-1000 and soon Toshiba will introduce a 720p60 camcorder. Unfortunately most reviewers trash these camcorders becuase they think that only 1080i is real high definition. For this reason Samsung will soon dump its 60p progressive scan technology in favor of 1080i60 and 1080p30.
Just deinterlace using a 'motion-adaptive field doubling deinterlacer'. The effective resolution of a properly deinterlaced 1080i video is more or less 720p.
always wondered something.. this is mostly technical question... instead of making us throw away half the fields by deinterlacing, why cant the camera grab odd and even fields at same exact time and put them side by side getting 1080.. instead of showing half of them in even and other half in odd fields 60 times a second, forcing one to have to chose between them in post? i saw the clip ghost shot by hv20. its sooo beautiful. but why oh why the interlace lines as the price for higher res? i understand its how tvs worked ... but isnt hv20 for hd screens? therefore not regular interlaced tvs?
forgive the silly questions :) i like feedbacks from all you guys
High Definition television was actually invented about 10 years before digital television so at that time HDTV was an analog technology that used interlaced 1080i cathode ray tube televisions as its display medium. Analog interlace HDTV was never sucessfull because it was a bandwidth hog and proved uneconomical. Later second generation HDTV were invented that used digital compression technology progressive scanning along with flat panel progressive displays. Although this new technology was so much superior to the old technology and although the computer industry dumped its interlaced displays in favor of progressive displays the fact remained that interlaced analog television had such a long 60 year legacy that the television and electronic executives refused to give up on obsolete technology. The hard line attitude of the television industry was that the 480i interlace format was The official NTSC Standard Definition for 60 years so it must be good enough for the digital age.
When the full high definition 1080i interlace television displays went on the market they were sold under the assumption that only 1080i is real high definition so steer clear of the 720p displays. However the consumers did not buy into this. Consumers when choosing a television chose large screen sizes over higher resolution and most consumers wanted the flat panel progressive displays rather than the big butt interlace displays. But when consumers buy video cameras it is a different story. Since 1080i is a bigger number than 720p consumers think they are getting better quality by going with an interlace format even though progressive scan cameras are better.
wow.. thanks for the detailed answer :) much history in the interlaced hd.. but hv20 is relatively new.. why did they make a 1080 interlaced hv20 now? Surely most owners of the hv20 cant use 1080i without seing the weird motion odd and even lines?
