mikkowilson said:It's all in the chips!
Or rather, CHIP.
A one CCD camera just has a simple bayer filter on the chip, this won't block IR. The restult, a one chip camera will always see IR. But that's bad in normal shooting, so they build a small IR blockign filter into the camera. Nice and simple.
When you turn on "Nightshot" (or whatever you call it) the camera jsut swings this IR blockign filter out of the way and the CCDs see IR!
However a 3-chip camera uses a prism (AKA: "Beam splitter") that splits the incoming light out to the 3 CCDs based on their wavelength. Only light matching the right wavelength can pass through the prism. IR is not one of these wavelengths, and therefor it's practically impossible to get IR to the chips. And thus there is no nightshot on a 3-CCD camera.
- Mikko
mikkowilson said:Not sure. I recall that some 3CCD cams can't see any IR, even from a remote.
However I think that maybe a little IR does get through (such as from a high intensity source, like a remote) but most of it is blocked, making it useless for the more sensitive shooting of reflected IR needed for nightshot.
Nightshot was originally an afterthought, making use of a side effect. I doubt they would pour money into making CCDs that could specially see IR. Though those very first few Sony nightshot cameras (that were too sensitive, and could see through clothes) seem to be prety valuable if you can find one.
- Mikko
