Jim Martin
DVXuser Sponsor
Well done Eric!......
Jim Martin
CinemaWorks
Jim Martin
CinemaWorks
Most of my event work involves shooting promos style videos. Basically, interviews and b-roll. Shallower (say f/2.8-f/5.6, so not super shallow) interviews on a large sensor camera tend to look better. For b-roll, it depends. Shallow can help some shots, others are better with deep depth of field. I think when comparing a large sensor camera to a small sensor camera people talk too much about the depth of field differences and ignore that a large sensor cameras has better image quality - dynamic range, colors, sharpness, low light, etc. I have not seen any DVX200 footage that impressed me and as such I would not consider it acceptable image quality for most of the work I do. In other words, for most shoots, too great of a cost to pay for getting a deeper depth of field and all-in-one lens.
Since large sensor cameras are also better in low light, it means you can raise the ISO, stop them down, and still get a pretty deep depth of field when desired.
You still don't get an all-in-one servo lens, but I've yet to have a job that needed that, as typically interviews and b-roll allow time to change lenses, at least for how I shoot.
I can see how some shoots such as sports could rely more heavily on an all-in-one lens setup.
Your interviews do looks really good, Rob. Glad you're not in my market!
What is your typical camera and key light setup?
I'd like to start incorporating a book light, or just a softer key in general, but don't feel my Astras are up to the task. Skypanel is perhaps a bit much for a one-man-band, but the Litepanels Gemini I've got my eye on.
Sure, you can gang up a lot of lights that you already have to make things work. But to do so regularly means each and every shoot will require that additional setup time, which reflects back on you as someone who takes extra time to setup when there is more streamlined equipment available which the client could have paid you the rental for. For most clients I charge for the amount of gear I'm bringing, so the more gear I own, the more money I can charge.I think you are suffering from gear lust and trying to justify it with "I need it for a softer key." I have seen clients gang up two 2x4 Divas into a 4x4 diffusion frame as a key, I have seen them do that AND an additional piece 4x4 foamcore with a 1K or so bounced into into it, essentially making a 4x8 (landscape orientation) key. . .there are really no end to the things you can do with gear you probably already have.
Ah, the Area 48. That used to be my dream light. But I ended up going with Astras instead, particularly since the Astra Soft became available which is more similar to the Area 48 than what was previously available (during my dream period), but with internal bi-color and wifi control. I imagine the Area 48 still has a bit better colors than the Astras, and at 160w is more powerful (brighter) than the Astra's 110w. But the new 6x Astras I would imagine are just as bright, though they haven't come out with a 6x Astra Soft yet. BBS really kills you on accessories for that light. $2500 for the light, but then you may spend $1500 on accessories, so $4k for a 1x1 is rather steep. I guess that's still less than a Skypanel SC-30, but the SC-30 is a 200w light, so brighter.
The tight beam angle of the Astra makes it more difficult to shoot through a very large source since you'd have to back it up pretty far, and the Astra Soft probably doesn't have enough punch to work well for that. Hence me thinking the Gemini.
I've used umbrellas with the Astra. One of them is particularly large, which I'll bounce for quite a soft light source. Obviously not very easy to control, but in most cases I don't need the background flagged from from key light spill as I often go for a natural look over dramatic. Lately I've been more often shooting through a 53" five-in-one reflector diffusion as my key light. A bit more control than using the umbrellas.
I use the small softbox with the Astra when I either need the control the grid offers, want to keep things small and simple, or want a harder source (since the softbox is smaller). Don't think I've double diffused the Astra; I don't think it'd be bright enough to do so with the f-stop and ISO I typically like to shoot at. 1/4 diffusion probably wouldn't soften it that much.
The Astra Soft is basically a regular Astra with a (built-in) softbox on it, so if I don't need the control a grid offers, I'll often use the Astra Soft and forgo using the softbox on a regular Astra.
Whatever works for you, but that still seems like faulty logic. The skypanel etc. does not have a very large surface area, which is ultimately what determines the light's softness, so you'll STILL need to bounce/diffuse it, so you'll STILL require additional gear and the setup time that goes with it, so it seems your time savings are minimal by buying/using these new lights.
Basically what Rob wrote, but since I'd already started writing this I'll say the same stuff anyway...Whatever works for you, but that still seems like faulty logic. The skypanel etc. does not have a very large surface area, which is ultimately what determines the light's softness, so you'll STILL need to bounce/diffuse it, so you'll STILL require additional gear and the setup time that goes with it, so it seems your time savings are minimal by buying/using these new lights.
If you look at the shot at 1:46, you can see a Skypanel pointing upward. Then if you go back to looking at the shot at 1:21, while there are two Astras being bounced, you notice a large white bounce in the position of where the key should be (both bounced Astras are more on the fill side), which is lit up by some light. Assuming it's the same setup, it looks to me like the shot at 1:46 indicates that key bounce is lit with a Skypanel which is hidden from view behind the black flag in the shot at 1:21."In the Hans Zimmer video linked to above, it looks like they used the Skypanel a few feet away from a large bounce. An Astra would have been difficult to fill the large bounce in the setup they had since the Astra could only be put so far away from the bounce before hitting the floor or the interviewee."
Eric, if you look at the wide shot at the 1:21 mark of the video you can see that an Astra is being bounced into a 4x4 bead-board bounce.
That's the thing, eh? Just when you think you got it all figured out, you don't.
That's a nice, but not totally elaborate talking head lighting setup. You could do that alone if you had some time? Two camera when shooting OMB always slows me down though.
