looks like a pulldown issue.
this can happen sometimes when you have a dropped frame, which causes the capturing program to bug and leave in the pulldown for the remainder of the captured footage.
Try capturing it again, and look out for any corrupt frames.
Is there a better pulldown removal software than the one that comes with Final Cut?
Did you shoot 24p standard or 24pA? You can tell this by playing the tape in your camera; it should tell you on the LCD screen which mode it is.
If you shot standard 24p, you can't remove the pulldown with FCP; you have to use Cinema Tools. (If you try it with FCP, the pulldown cadence will be wrong and you'll end up with a mess.)
