Mark Smith
My Arri S-16 SR weighs about 15 - 18 lbs depending on lenses and accessories it can go higher because there is a larger selection of lenses ranging from very light weight primes to the monster 14.5 to 450 canon zoom.
There is quite a bit more to the film process that affects the image than video, but I'll tell you the new Kodak stocks are quite amazing: more sensitivity in the toe and the highlight range is greater as well.
Then there is the frame rate thing: My SR shoots anywhere between 1 and 200 FPS. the pool splash in Soaked was just north of 100 FPS which was all the speed I could get that day from my battery. I would have shot 150 FPS if the battery was game. Decided early on to use film sparingly and only in cases where we wanted an over crank or under crank. We made an exception for the hitch hiking and creek scenes as we had the camera SR loaded and I like the way the shot/scene looked through the lens. We shot 800 feet more or less and I think it added the right spice to the soup
Hope this helps.
BTW Stephanie and I are married so we do see each other frequently. She is cutting an hour long doc the she produced and directed and we're this close to picture lock...
Hope this helps.
