John Foundas
Looking for a mattbox for the AF.Going to use it with the Voightlander 25mm and 50mm lenses.Functional not crazy $$$$ Any suggestions?Thanks
Looking for a mattbox for the AF.Going to use it with the Voightlander 25mm and 50mm lenses.Functional not crazy $$$$ Any suggestions?Thanks![]()
Shooter, is this Nikkor problem only when you're using the mattebox, or do they flare all the time?
The issues with glare can be managed by lens shades and good light control. If you need to use more than the ND filters then the mattebox becomes a useful accessory. Other than that, it seems its only purpose is to make your rig look professional. Granted, I'm not an AF100 owner yet, but I have yet to read any good counter-arguments to those points.
.......QUOTE]
The Nikkors have potential to easily flare with or without a mattebox. eg shooting product on a white BG or simply bright sky bgs. We are constantly "fighting" it.
We use the mattebox to hold and exactly position the lens mattes by using the rails etc.
Without a mattebox it is impossible. Flags and eyelids dont achieve the same amount of cut required. Our mattes are almost exactly to the outer edge of frame (as they should be).
I remember seeing "filter trays" that would screw onto the front of a still cam lens and then you could "drop in" filters like gradients... cokin makes these... they won't cut the glare and flair and keep your blacks black like a mattebox though.I dont mind screwing on/off as I wouldn't be using regularly, just for outdoor wide shots/timelapse to prevent the sky blowing out,
I'm using a 24mm FD lens, can you recommend a good grad filter for this purpose (.6?)
