dakotapod
Finally ready to start shipping matte box - I have 20 good to go. :thumbsup:
Orders will be shipped in the order received. When out of stock, I will not take orders until a new batch is ready.
Matte Box Complete with French Flag is $189
Matte Box Complete with French Flag & Side Flags is $209
Boxes can be bought from here: >> LINK
Here is some pics and info for production model
Super light weight but durable aluminum that does not require a support system. Metal is finished with a bullet proof rubber coating. Comes with a removable French flag. Has the ability to hold 84mm filters [or P Series] Filters from Cokin, Tiffen, Hitech & Singh-Ray and others. I chose this filter size as it provides a huge range of filter options from $30 on the low end up to $180 on the high end. And tons in between. This gives the user the option to experiment with using filters without the burden of laying out a ton of cash
Installation
System mounts to front of stock lens. Aluminum adapter screws to filter threads and then matte box is snapped on. Installed and removed in seconds.
[SIZE=-1]Optional side blinders
The side flags can be added for $20 for the pair. They can be purchased at anytime for the same price.
Only shipping will have to apply if purchased after initial matte box order. [/SIZE]
[SIZE=-1]Entire box can be rotated fully loaded
[SIZE=-1]Rotating shade
To keep the weight and cost down the filters themselves can't rotate, but the entire matte box can be rotated for rotating grads if desired. Thumb screws are located on each side of holder [/SIZE][SIZE=-1]- Attaches to adapter, not the camera.[/SIZE][SIZE=-1]Filter holder
[/SIZE]
[SIZE=-1]Holds 3 - 2mm filters [84mm x 84mm, 84mm x 100mm, 84mm x 120mm, etc.] - Shown here with two filters[/SIZE]
[SIZE=-1]
[/SIZE]
[SIZE=-1]
[SIZE=-1]Compatibility:
72 and 58mm is stock. This WILL NOT work on the HVX
This 72mm system will work with the DVX series and XL series. This setup is shown on the DVX but can be used on any camera with a lens under 72mm with an adapter. Depending on your lens size there could be a slight delay in shipment. Sony VX2000/2100, PD150/170 use 58mm – This is the same price as the 72mm. No additional charge for adapter.
Please check your cameras specs and confirm availability before ordering. When ordering you must specify size or 72mm will be sent. If you use a non 72mm camera now and upgrade to the DVX or XL2 in the future all you will need is a new adapter ring. The matte box is the same. If you have two cameras with different thread sizes you can just get one additional ring for the extra camera.
Optional Sizes
On top of 72 and 58mm there is 49,52,55,62 & 67 available.
These can be substituted[SIZE=-1] at no charge but may delay shipping a week or so.
[/SIZE][/SIZE]
[SIZE=-1][SIZE=-1]An example of the range of 84mm filters @ BH Photo:[/SIZE]
http://www.bhphotovideo.com/bnh/controller/home?A=search&ci=4032&Q=&O=NavBar
[SIZE=-1]A site that shows some examples of what effects various filters provide.
Effect will vary slightly from brand to brand, but this will give you a pretty good idea:[/SIZE]
http://www.geocities.com/cokinfiltersystem/theguide.htm
[FONT=Verdana, Arial, Helvetica, sans-serif]ORDER HERE With PayPal[/FONT]
[/SIZE]
[/SIZE]
