lanceedmands
Does anybody here have any experience with a tapeless color correct?
I have a 720p sequence exported as an image sequence that will be ingested into a Da Vinci for color correct...
I spoke to a post house here in NYC that will take TIFF or DPX sequences. FCP doesn't export in DPX, but it will do TIFF. If anyone here has experience color correcting tapelessly I'm curious to know the optimal settings and quirks of the process. For example-- my frames come out "squeezed" due to the 960x720 that is converted to 1280x720 in FCP. Will the Da Vinci also make this correction or must I manually type in the frame size? Should the compression be on "none"? Do I set the sequence for 24fps if its 23.98 (24p)?
Thanks a lot for any advice you could give!
