I have both and did some unscientific tests when the C70 got the RAW update. In a nutshell I found the image quality virtually indistinguishable. The C300mk3 RAW files are less compressed and show ever so slightly fewer artefacts, but I could only see this on an unmoving image at 400%.
Shooting XFAVC there is no difference.
I prefer using the C300mk3 body but end up using the C70 more often simply because I travel by air a lot and it’s so portable.
Hi Norway,
The 24-105 has been practically married to my C70 since I bought it, usually paired with the .71 adapter. The IS works just fine on mine - perhaps check you have the latest firmware for your C70, the lens and the adapter.
I also use the digital IS quite a bit; if you’re careful with it the results are good.
I’m actually selling the 24-105 at the moment for an RF24-70 as I got a good deal and want the 24-70 for stills, but the 24-105 is a great match for the C70
Hi Norway,
Does the .71 adaptor change the FOV of the 24-105? Does it become the equivalent of something like a 16mm-70mm give or take?
Here's in depth comparison of the two cameras from 2 years ago. I don't know if it all still holds true but check it out at https://www.youtube.com/watch?v=YlvGE4IxgNE
