Richard Allen Crook
I monitor via the shuttles hdmi out, look for the little "signal" light, and of course I cannot record anything. Ill check the sdi/hdmi selection, thanks for the help!
Hey guys, I'm having trouble here. I'm trying to record 720p 60p to the shuttle from the f3. Can any of you tell me how to do this? I tried plugging into sdiA or the SDI out plugs, and I can't get it to work.![]()
I wonder what would create a better flat image using this shuttle to prores, the c300, F3 or scarlet??
First you have to define "better flat image". They are all very different cameras with different strengths In different situations. And there are always considerations besides image quality.
I mean a flat image suitable for grading
I understood that, my point was more that image quality is subjective and complex. F3 slog probably has slightly more latitude, but c300 is quite a bit sharper. Both cameras have different types and levels of aliasing. Probably if I wanted more latitude I would choose the F3, but if resolution was more important I might use the c300. Why do you want a flat image anyway? Wouldn't an image that requires less post work be preferable in some situations? Do you see flat recording as simply a way to overcome limited bit depth or is it something else?
