The 200A is not a lot less expensive. B&H shows it at $5199 with a 16GB P2 card. Enough to record 16 minutes of 1080 video. You'd need 4 to get an hour. Purchasing 3 more 16GB P2 cards (@ $849 each according to B&H) is an additional $2547. Add that to the $5199 camera price and you're at $7749. The EX1 lists at $6449 at B&H and comes with an hour of media already.Well, frankly, it certainly improves its position &em; it now matches the EX1 for 1080P sensitivity, it probably comes very close to matching the EX1 for noise, and it's a whole lot less expensive. There are still many differences between those two cameras, but if you wanted an HVX but were tempted by the EX1's low light performance and low-noise imagery, the HVX200A is now much more competitive on those fronts (still not as sharp, but then again the HVX200A doesn't have any of the rolling-shutter issues or build quality issues that affect the EX1, and it's $1400 cheaper)
I'm pretty sure that Panasonic's new sensor block that it's putting on the 200A, the 170, and the 150 comes out to about 1280x720 photosites, thus showing why Barry considered the 200A to be much sharper than the 200.The amazing thing is that it offers that better noise performance on a 1920x1080 native image unlike the 960x540 native image of the HVX200A.
Still pixel shifting is not upsampling. It's more like using a Bayer pattern on a CMOS sensor.
The EX-1, however, does produce a much sharper image, as long as you are not panning the camera.
I didn't notice a sharpness increase in 200A vs. 200. Sensitivity and noise and smear were all greatly improved, but sharpness seemed equivalent.thus showing why Barry considered the 200A to be much sharper than the 200
Panasonic's already doing 1920x1080 recording on commodity media with the HMC150.
Also, EX1 shoots only HD, so if you need to shoot SD, you can't. This all depends what you'll be doing with your camera, but in my case I might still have many clients that request 4:3 SD footage.
Ive always been a sony user and when the EX1 came out i decided that was the one im going for. The more time to an SxS card than a P2 card, the marked length lens, and the native 1080 CMOS turned me on to it. But personally, the 14 second wait time between modes and the rolling shutter were enough to turn me off real quick.
I don't mean recording. I mean sensors.
My bad. I'll check my sources next time.I didn't notice a sharpness increase in 200A vs. 200. Sensitivity and noise and smear were all greatly improved, but sharpness seemed equivalent.
This seems like an odd statement. I assume you have purchased Hollywood movies on VHS and DVD. They weren't shot that way. Rendering out to SD-DVD is trivial.
Where did you hear it took 14 seconds to switch modes? And did you try one to see if the rolling shutter was an issue? Doesn't seem to bother the RED guys much.
No, that's what it takes.I read a few places that the EX1 takes 14 seconds or so to go from playback mode to record mode. Was I misinformed?
The Red One, at Build 14 or 15, had identical rolling shutter issues to the EX1. Jannard says they've been improved for build 16. I had Build 16 tested for HMI issues and they appeared to be every bit as prevalent as in Build 14. I bought a roll of 35mm film to test skew issues against a 35mm camera, but I haven't gotten to run that test yet.I've never heard of rolling shutter issues on the Red, but I have for the
