HVX200 Newbie Help
estebanzissou
Hi Guys,
I have just purchased a Panasonic HVX200 (NTSC) and I wish to shoot 1080/24p and then edit in Final Cut Pro 6. I am fairly new to this so would appreciate any resources you can send me to.
My initial questions are as follows:
1) Which mode should I shoot in 1080i p or pA? Im a little confused here. Am I right in thinking something has to be done to the footage after import as it's showing up as 30 fps.
2) How should I correctly setup Final Cut Pro 6 for working in this format?
Thanks in advance!
Shoot 24pA, not 24p in the 1080 mode.
Use log and transfer to ingest and to get to 24p, check remove pulldown in the L/T preferences.
There is a sticky about this somewhere here.
