Here in are some pictures of the RAID/P2 board and two ports that you will find just under the battery. The latter is exposed without any intrusion to the case so I am really curious what this is for, anyone know?
Pictures show:
* ports behind battery
* Pictures of P2 (RAID?) controller
Also, im running into several chips for which I cannot find any documentation. For instance, the Toshiba chip pictured in the 3rd image below. Anyone have clues?
To recap the goals:
I'm working on a few objectives in reverse engineering of the HVX200 at the moment.
1. provide support for generic USB or firewire disks.
2. Provide information on P2 cards (which appear to be generic SD+RAID derivers over PCMCIA actually) to be able to build drivers in linux.
3. Explore swapping chips on P2 cards to increase storage.
In the process my first objective is to get some way to debug and explore the system. I already have one clear route which is that I can make a script to execute and print info either to the LCD or save it to a SD card. I'm still looking for something like a console for more interactive exploration. It appears their might be drivers onboard for a PCMCIA network card.
I think i will spend a little more time going over the internals to see if i find something that will help in debugging. Otherwise, its back to the software and drivers. First and foremost ordering the PCMCIA network or console cards that they have left the drivers in for.
I will post updates to http://deadhacker.com and here when I have them.
Pictures show:
To recap the goals:
