Hi,
Despite having read several how-to articles and viewing the archives here, I am still a little unclear on how to make best use of the HVX200's variable rate feature.
What I have done successfully is the slow motion feature that's described here:
http://www.studiodaily.com/studiomonthly/tutorials/trainup/5993.html
First of all, is that generally considered the correct setup?
If so, what's the best way to handle something that I might want at normal and slow motion? For example, a skater coming towards the ramp should be at a normal frame rate but on the jump, I want to use slow motion. Would I shoot all of it at the faster rate described above, use that directly in the 24p timeline for the slow motion part and convert the rest the clip to 24p? That is what I assume, based on reading this section of article on the History Channel shoot:
O’Brien added, “The most useful feature of the camera was its ability to shoot 24 or 60 frames for any particular shot. Having 60 frames to use as a slow motion shot in a 24 frame timeline was the closest I've come to the days of 16mm, where you could dial up to 72 frames for slow motion. The 60-fps shots can be easily converted in Final Cut Pro to 24-fps if we decide not to use the shot as slow motion. Knowing this, we were unafraid and shot anything that we might want to be slow motion at 60 frames. This gave us a freedom we would not have had on film, where a slow motion shot would be expensive to convert back to normal.
Just writing this down is making me think more clearly that this is the best path but opinions would be much appreciated.
Regards,
fh
Regards,
fh
