HVX > P2 > 1234 Audio Issue
JWinter
Weird audio issue in Raylight/Vegas
I have the camera set at: CH 1 Select - Input 1 (using a senn wireless) and CH 2 Select - Int (R) for Internal R Mic...The logic being I could control the level of my senn mic + the level of the internal mic.
I have 4 channels of audio in my time line but there is a weird sync issue where there a 2-4 second delay between tracks-
even weirder --- I don't hear the delay in P2 viewer or FCP Log and Transfer
I've had a similar issue - mine was due to the speed of my computer. When I got a faster computer the problem disappeared.
well...i will be uing bootcamp on a quad core so I guess that will be the test...this is a 64 X2 Dual Core AMD @ 1.78 GHz + 2GIG RAM
Hope it all works out for you, mate. I know how annoying stuff like that can be.
From DVFilm Support:
"Thanks for contacting DVFilm Support. Sorry that you are having problems.
We are investigating this problem, but it the meantime we suggest put all your clips in the timeline, save the project,
close Vegas, then delete all the .sfk .sfk0 and .sfk1 files that Vegas creates in the folder with the MXF files. Then
restart Vegas. Let us know if that does not fix the problem."
I tried that and it didn't fix the problem. At least support is responsive. I'll post results of troubleshooting here when a fix is found....
as well...please post if you had similar issue
