ok so ive had the new cam for a week or so now. .. ive toyed around and found it quite easy to navigate through everything to get the results i want. the menu system is a little confusing at first just because there are so many selections and settings to choose from though. anyhow.. heres some numbered things i have to say about the cam.
#1: ( this is only #1 cause its bothering me so much with all the chatter.)
noise: whatever.. its no more noisy than the DVX. if you want to shoot in the dark ...use nightvision. ..if you want to shoot a film.. even if its a dark scene.. do it the right way.. shoot it brighter and darken in post. but again.. its no more noisy than the DVX. Ive found that on my production model the cine gamma and matrix settings with normal or even slightly increased detail arent really any noisier than the normal settings in any conditions i would consider acceptable to shoot in. in darker conditions, the cine matrix can give a little chroma noise exactly like the DVX. basically .. imho if your having noise issues, its your fault and not the cameras. after all it is a LIGHT recording device.. you need to give it something real to work with.
#2: resolution: wow!.. and i mean wow!.. this thing is definitely high def. I can see every little piece of texture on a seemingly smooth surface.. just amazing. im definitely not going to worry about the resolution being good enough for film blowup. cause it is.. period. even the SD DVX did a decent job, but this is just cake.
#3: P2 shooting: ...i never want to see a tape again.. ever.. enough said.
ive found that using the HVX in the USB 2.0 mode is easier than the firewire mode for computer connection since its faster and plug and play responsive.
#4: increased zoom range: i really like this.. the little bit of extra shallow DOF on the long end of the lense is nice.
#5: 1080p vs 720p: the 720p image seems to be smoother in image tonality, but the 1080p definitely yeilds more resolution. either way thery are both very lovely high def images.
...anyway im going to do some shoting right now and then come back and post some images in a couple hours or so.. nothing fancy. just some basic stuff, and ill try to get some more sample stuff shot tommorow.
