HVX-FCPStudio question
thinksnow
I am just starting to cut HVX footage, and for some reason I am unable to apply a dissolve between 2 clips. I can apply a fade in/out at the beginning or end of the sequence, but if the clips are joined, nothing will work at the edit point. The Item Properties of the clips all match, and the sequence settings are the same as the clips. It all works in SD mode. Any thoughts?
Michael
Are there any frames beyond your in and out points where the clips join? You need those "handles" to do a cross-dissolve. (You can apply a fade without them.)
Kevin
