HD Studio Belgium
Hi,
I just received a SWIT S-1080BS LCD Monitor ...
(the cheaper one ... paid 935 Euro ex VAT at 21% )
It has composite and S-Video input ... and Y Pb Pr In put ... (YUV) ...
In S-Video and component mode connected to the HVX-200 the colors are spot on but of SD resolution and looks like it !. Connected to the Component special plug from the HVX- to these three component imputs on the LCD monitor it gives HD resolution ... ( well it looks a lot better even on the units 800 by 480 Resolution) ... however ... by default the colors are of ... which I expected ... as the inputs are not RGB component but YUV. However after a bit of tuning and adjusting the RGB values in the menu it calibrates pretty well.
Question is though ... I have now adjusted these levels to respectively R 47 G 70 and B 65 ... by using my own vision ... IS THERE SOME KIND OF CONVERSION TABLE as a standard for this kind of unorthodox tweaking ?
The quality of the monitor in this mode is very good ... no tails whatsoever and very very detailed ...
Curious for your reactions guys ... Greetings from Brugge - Belgium
