HVX-200 VFR slo mo problems??
jlowe
found this forum while looking for answers to a problem i've started to have. when i set the camera up to shoot 60fps in 720/60 for slow-mo, it takes all the changes in the menus, shoots fine but on playback...no slow-mo! i tested it doing some under-cranking at 12 and that works on playback. slow-mo 60fps was working fine 2 weeks ago...not sure if i bumped something. checked all the settings (i think) still no worky.
any ideas?
thanks.
jeff
Do you have the pN shooting option on? Shoot 24pN. Change the frame rate to 60fps after you selected the native mode.
Sounds like you were shooting in regular shooting mode without the native option turned on.
the camera is playing 60p back at 60p
so you either need to bring it into an NLE into a 30p or 24p timeline and then render it out.
Or
Put the camera in 24pa or 24pN (or 30p) mode and then change the recording to speed to 60p then when you play back it will be slow motion playing back at the 24p or 30p frame rate.
