africanmarty
how should i do this, wich way is better ?
Capture the HDVp material as HDVp from the camera (real itme), edit the HVDp video and then render to SD ( exporting as a progressive file).
CAM -> capture as HVDp -> edit HDVp -> export/render to SDp
Capture the HDVp material as SD progressive from the camera (real time), edit and render as normal SD progressive.
CAM -> capture as SDp -> edit SDp -> export/render to SDp
i guess the second method would be quicker to render ect but would i look as good or as same as the top method ?
thanks.
if these are incorrect how do you guys to it ?
PS: i'm working with PAL 25p and using premier pro 2.0
- thanks Marty
thanks.
- thanks Marty
