HV10 audio
markinhifi
There doesn't seem to be a forum for HV10 so i'll post this here.
I know the camera has an AV IN/OUT so does this mean that it's possible to hook up a microphone to this? Doesn't with A in AV stand for audio? So, isn't that Audio In? Unless i'm mistaken.
And if not, is there any other way possible to attach a microphone to this camera? Or am I screwed?
Well you probably have several options - you could try a XLR to 1/8" adapter to get a Mic In to the camera. But - you should be careful, an A/V jack does not necessarily mean the same as "audio in" or "mic in." I am not familiar with the HV10, but I have worked with GL's, XL's, HVX200's, XHA1's, etc and some of them had 1/8" "mic in" jacks so that is what you could use the XLR converter for.
I would consult your manual to find what port will provide audio in, then look for an adapter if you want to use an XLR microphone.
John
You need a mic in not AV in for external mic. HV10 doesn't have this feature probably due to it's form.
