As far as I know, the HDX900 does not do variable framerates but it does have an HD sensor whereas the HPX500 uses an SD sensor like the HVX and achieves HD resolution through pixel shifting.
Marco
The hvx is not an SD sensor - pixel shift doesnt make resolution from nothing - its a smart way of having less noise and more resolution.
Yes it is an SD sensor. An HD sensor is slightly above 2 megapixels whereas the HVX sensor is around 0.6 megapixels.
Pixel shift is a smart way of achieving HD-like results with a sensor that has less pixels. I don't see that noise has anything to do with it because the HVX is slower and noisier than the Canon HV20 with its full 1920x1080 sensor.
Pixel shift works pretty well but it's no substitute for the real thing. The image from an HV20 is sharper, in my opinion, but my HVX holds up very well against the XLH1.
Marco
There's nothing about this statement that's correct though. It shows a fundamental misunderstanding of how sensors are read and interpreted. You do not ever read one chip -- individual pixel counts on a single chip are largely irrelevant. It's the total combination of all the chips being read together that produces the final image. And in that context, the HVX resolves a 2K image; the imaging block is a 2K imaging block (regardless of how many pixels are on each individual chip).Yes it is an SD sensor. An HD sensor is slightly above 2 megapixels whereas the HVX sensor is around 0.6 megapixels.
Marco, come on. This statement is so incredibly easy to disprove, why do you even say things like this? The HV20 is an ISO of 80. The HVX is an ISO of 320. The HVX is two full stops faster than the HV20. To make an HV20 "faster" than an HVX you'd have to pile in 18dB of gain, and at that point it's far noisier than the HVX.I don't see that noise has anything to do with it because the HVX is slower and noisier than the Canon HV20 with its full 1920x1080 sensor.
My mistake, it is the XH-A1 that is faster and less noisy even though it has more pixels on its sensors.The HV20 is an ISO of 80. The HVX is an ISO of 320.
I'm eager to know how the green and blue sensors contribute any data besides luminance when recording a red object.It's the total combination of all the chips being read together that produces the final image.
