It seems like this distortion being caused is a result of excessive sound pressure on the microphone in use. This would most certainly cause audible distortion on any recording devise.
I'm not a sound expect by any means, but I would think that it's easier to distort a condenser mic as compared to a dynamic mic, especially a condenser shotgun which is designed to bring sounds that are further away closer, in audible terms ( and rejecting off access sound). I think this is why I was able to replicate the problem with the ME66 and could not with a dynamic mic.
Now My question to you Chris is...
Wouldn't this distortion occur on any camera along with the signal being recorded, because the mic is being overloaded?
The issue in question here is why is it occurring on the HPX250 with the level pots turned down to no gain?
I did another test with the ME66 and did not purposely overload the mic, and the recording was fine with no audible distortion.
It would seem that maybe the preamps in the HPX250 are a little more sensitive than others, maybe 0 gain on the level controls is not really 0 gain.
Not high enough to record a normal signal, but just able to pass through the clipping distortion that occurs on an overloaded microphone?
Certainly microphone choice is critical with any camera depending upon your particular situation, and if in an extremely loud environment it may be wise to choose
a less sensitive mic.
Does this seem Valid?
