Chris Dumont
Hi all,
Any help with this would be much appreciated.
The issue
I am experiencing an issue with my recently purchased HPX 250, that when I am using the camera in a relatively loud environment with a shotgun mic attached via XLR, I am getting a strange electronic distortion through the camera (please listen to audio sample attached). I am controlling the levels on the camera manually with the level around-18/-12db. This "electronic distortion" then peaks over that level. In trying to identify what was causing this to happen I turned the level completely to zero. The "electronic distortion" still gets through and records to the card. This is how I have a clean recording of the distortion in the audio sample.
Equipment
HPX250
Sennheiser ME66 with K6 power module.
Rycote Softie
XLR Cable (tried multiple cables)
Troubleshooting
This is everything I have done to try and find the cause of the issue but nothing has resolved it.
Changed XLR cables
Changed Channel on camera (different XLR port)
Turned the camera limiter on and off
Turned the levels down to zero (this is how audio sample was recorded)
Changed the internal (menu) mic gain option from default -50db to other two options -40db and -60db
Replicated the issue at home in a quiet environment by making a loud noise into the microphone.
Turned phantom power off and ran just on mic battery, removed battery and powered just from camera.
Not getting anywhere, I then took the camera to the dealership I bought it from and we replicated the issue not only on my camera but also on the HPX250 that they have in the showroom (leading me to believe this might be a design fault in the camera).
At the dealership we also -
Used a different mic on the camera (Rode NT3?) and ran the same test (making a loud noise into the mic) which gave us the same result of the "electronic distortion". We then ran the same test on the Canon XF305 and another Sony camera of a similar level with both mics and these did not allow the signal through. This unfortunately indicates to us that the fault is with the camera(s) not the microphone.
Verdict
I am not an audio expert nor a sound man, however, my theory is that the loud noise is causing the mic to create an electrical signal that the camera is not resisting??
I have spoken to a sound recordist that I know and played the audio sample to him, he feels that its a problem with the pre amps on the camera.
My dealership are currently doing their best to resolve this issue for me, but at the moment it is still on going. Has anyone had this issue with this camera yet? Does anyone know what this might be?
If you do own the camera, could you try the test and make a loud noise into your mic and see if that signal breaks through.
This is my first post on a forum like this so I hope this is all clear and explains the issue, look forward to your replies.
Audio Sample
I couldn't work out how to post audio on the forum so here is a link to the audio on youtube.
The issue
Equipment
HPX250
Rycote Softie
Troubleshooting
Changed XLR cables
Verdict
Audio Sample
