HPX170 Slomo Mistake
kgordon
I intended to film an event in slomo and instead of setting the camera to 720/24pn/film cam with a frame rate of 60, I set it to 720/60p/film cam with a frame rate of 60, shich seems to have canceled out the slomo. What can I do to turn this footage into true slomo?
That shouldn't be a big deal, you recorded the number of frames that you intended to, you just need to slow down the playback to 24fps.
Right - just put the footage on a 24p timeline and play it back at 40% speed and it will look exactly like as if you'd shot it in 720/24pN @ 60fps.
