Dino
I am very sad to say that after some brief test shots with my HPX170 and Letus Ultimate/Nikon primes, I will have to return the camera. There is a horrendous amount of play/slop between the body and zoom ring. When mounting a 35mm DOF adapter, it is exacerbated, causing a huge side to side/up/down shift, especially with a follow focus.
This is certainly more evident with the weight of a 35mm DOF adapter/prime lens, but even a wide angle adapter or matte box could be an issue. I hope this is just this HPX170, but would like to know if anybody else has noticed slop between the body and zoom ring? This is not an issue I had with an HVX200A or EX1.
UPDATE:
The lateral play in the HPX170 lens is quite evident at long focal lengths when trying to manually focus. This is a problem when just trying to use the camera in a normal way. The image shift if very obvious and would ruin any take. Below are some sample clips from forum members:
http://homepage.mac.com/segarza/hpx170/imageshift.movhttp://vimeo.com/1873268
http://itchyhousefilms.com/films/tap.mov
http://www.pitchproductions.com/HPX/...test-small.wmv
UPDATE:
