anothermember
EDIT-SEE BELOW
I just posted all the items on ebay with NO RESERVE so you can get some real good deals. I need to sell the gear and last time I did an auction it didn't sell because I had reserve prices.
I'm selling all of the following items individually, except for the camera and the hard case, which go together. All the gear is in top working condition. This equipment has been taken care of meticulously and I've done the best I can to describe its condition accurately. Make an offer!
http://www.flickr.com/photos/rodmyre...7624358720281/
HPX 170
The camera lens has no scratches or dust. The body is in great shape. No dings or scratches. The lcd is clear and clean. Also included are: Original single-battery charger/AC power, Remote Control, Camera Carrying Strap, Component Monitor Cable, Barry's HVX/HPX book. Camera is a little over 400 hours.
Hardigg Storm Case iM2720 w/laser cut foam ($-no charge, comes with 170)
The case has a telescoping handle which is great for traveling, especially rolling around airports. The laser-cut foam holds the camera very snugly, and has flown several times (checked luggage) without any incident. Also, the latches have a push-button release that is MUCH easier than the standard Pelican snap-release latches and just as secure. The case is watertight and the seals have been kept clean at all times. The inline wheel area has some scuffs from sliding around but nothing major.
x2 16GB "R Series" P2 Cards
The P2 cards have been used for a relatively short amount of time (given Panasonic's claim they can be used 100,000 cycles) and have never lost a frame of footage. I have the plastic cases and rubber caps for all the cards. For some reason I forgot to take a picture of the 3rd card, but it's in the exact same condition as the other 2.
-x4 Panasonic 5400maH batteries
Almost new, purchased recently and barely used. Hold their charge and haven't been dropped.
Century Pro Series HD .8x Wide Angle Lens
Lens is in Mint condition, no scratches or dust. Increases field of view by 20% while maintaining focus and sharpness throughout the full zoom range. Comes with lens bag.
If you're in the LA area I can do a local dropoff/pickup.
-Rod
HPX 170
-Rod
