+1 Also interested.
Well, given the lack of response, it appears that no one on this forum is using the aforementioned combo. I have queried several other forums and it appears that with the exception of one individual who is using the nanoflash with his HPX 500, most others are using it with EX series cameras. The Convergent Design Sales Mgr. has stated on Creative Cow that they have tested the device with the Hpx 170 but did not include any information as to whether there was any noted benefit from the combination other than the ability to use CF cards. A telephone conversation with that same individual was even less revealing... he apparently did not recall his Creative Cow post.
So, if the only advantage turns out to be the CF cards, there may still be reason to consider the purchase given that the Panasonic 5 card reader sells for about $1900.00 and you still need P2 cards, whereas, for another $900.00 (less than the cost of one 64GB P2 "E" card) you could buy the Nanoflash, which affords one the use of less expensive CF cards and the ability to transfer data to computer with an inexpensive and readily available card reader. Food for thought! Unfortunately, the original question remains unanswered, although, I suspect that since the 170 is already recording 4.2.2 at 100Mbs that there would be little if any other benefit from the 170/Nanoflash combination. I will add, however, that the gentleman with the Hpx500 did say that he has noted an increase in image detail with the use of the Nanoflash.
Well with the P2 E-Series cards, for around 1000$ you get an hour of 1080p recording time - enough for most needs...
This Nanoflash should have come out 2 years ago and would have sold like bread...
