i would advise against getting any new equipment right now. a $200-$300 audio recorder is a completely different product than a $3400 video recorder. it's like asking if you should go with the toyota corolla or the ford super duty. the last thing you want is to impulsively buy something and then realize it's not right for the job. if i were you i would focus on improving technique and hold off on buying until you have a budget and know exactly what you want.
My first intended venture was to be a DVX Fest. One of the Horror films. I thought that would be a good way to learn. Several years ago my wife and I actually worked on it. But, we were also working 14-8/7/365 trying to monetize the web and our print content digitally, so we have been working harder for less these past 10 years. That took away our time to devote to the first try. We never gave up hope, and when we do episodes of dagameshow.com, we try to do this or that, but the end product is a pretty messy hodge lodge. We make no excuses. It has a small fan base that gets some laughs and that is it.
When I am told I can't do something I fight it, but let me say that after Marie and I tried to shoot our little DVX hoarfrost we got a very good smack in the face. So, we cut way back in terms of our own expectations and have tried to bang out 30-minute shows to get used to the entire workflow, from concept to delivery. Granted it is crap. But, we now have had years of paying out dues on a l=very low level and just want to improve. We have no delusions. We know what we make will be laughable. But at least we aren't sitting on our asses complaining about how tough life is ;-)
I regret this post.
I love sound, and on Maui, we have bird and animals and noises of all kinds. Inside the crater, it is surreal. I was hoping I might be able to include that somehow an will follow your guidance.
You are the second person who told me to go Tascam and that is all I need to hear. Done. i'll have one in week.
Right. Re: "smooth out dialog edits" what does that mean?
These numbers are so very helpful thanks Alex. I have two Genelec monitors. Years ago, in this exact forum, I spent a lot of time cobbling together an editing bay, with advice given, but could not afford the rent and am now starting from scratch, probably making my editing bay in my bedroom. I will cover the walls and ceiling and floor and try to make a good sound room with what I have.
Consider this: accepting that it's community-access-level production and writing it off as "it's going to messy" because of that doesn't help you hone your skills. Take each and every project you have as if it is your career-maker. Treat it as a professional production. Who cares if it's destined just for a small audience on a website? Or if it's "only" for YouTube? Make it count!
I watched parts of a couple of episodes. First and foremost, the sound is suffering from way too much distortion. This is where gain staging comes in.
With any wireless system (which system do you have, by the way?),
each one must be carefully set to maximize the S/N ratio while leaving enough headroom to avoid distortion. If you have four stages of gain in your signal chain, and the signal gets distorted in the first one, it doesn't matter what the meters say downstream; the distortion is there to stay.
There's also a big wind problem. Some Rycote Overcovers will help, or some furry windjammers made for lavs.
So you understand that this is a large undertaking, and expectations should be kept to realistic and reasonable levels. But if you make something, and it turns out to be ridiculously bad, at least you made something... and learned (hopefully) from the experience. Figure out why is was so awful, and then figure out how to avoid that on the next one. Make another. Still not great? Well, did you make the same mistakes as last time? Probably a couple (some of this is requires more than one failure to learn), but you probably made some different mistakes. Rinse, repeat. Each new project will be better than the last, and will offer its own learning experience.
Starting off with shorts is a great way to go. Vimeo's "Weekend Challenge" series is a good place to start, simply for honing some basic skills. And it looks like there may be a new DVX fest coming up. Make something, and then make something else. And then something else...
One thing I will say is that you might want to look seriously at adding a small, handheld recorder to your kit. Look at the TASCAM DR-22WL. And get a furry windscreen for it (I believe Redhead Windscreens is based in HI). These little devices are easy to carry anywhere, any time, and to have ready at a moment's notice should you find yourself in an environment with a really cool sound. Grab your recorder and headphones, and record! I carry mine with me when I travel and snag ambient sound beds wherever I can... airplanes, taxi cabs, subways, forests, lakes, boats...
and better pre-amps than what your DSLR can ever hope to offer). It doesn't matter WHAT you record to if the mic isn't applied properly. Whether the TASCAM devices are actually right for you, well, that needs to be discerned before you pull the trigger on ordering one. There are other fine recorders out there for the budget-conscious, but the first determination is need.
When editing dialog, if you cut two lines together and that noise floor disappears for a moment, it is noticeable. So, by recording room tone at the end of a scene, you have a chunk of that sound from which to clip a little bit for filling that gap.
Again, the numbers are really just spitballing. Please do not use them to drive your mix as a hard and fast rule.
The first and most important step is to get your room properly setup and treated, and acoustic treatment doesn't necessarily mean covering your entire room, floor to cieling. Some absorption on the wall behind your desk and monitors, and some bass traps in the corners, plus a patch of absorption just about anywhere that may cause reflections in the mixing position. Check THESE webisodes on YouTube to see what simple things can be done to create a better mixing environment.
Once your room is treated, set your monitors to a decent mix level. While proper mix stages may be set to 85dB SPL, a small room like that is better off setting to 79dB SPL. That means running pink noise through each speaker and using an SPL meter (acoustic sound pressure level) to make sure that you have the nominal level coming from that speaker at the mix position. Once you're there, trust your ears to make the mix. The meters are all well and good, and are quite helpful (especially to see that nothing is hitting red), but mix by ear more than by meter.
