How to eliminate video flicker? Shooting Neon and using fluorescent lights.
Picturequest
Hello!
I've done some shots at 720p 30 fps. My only light source was the light from a 52" LCD. (I'm in the US). On play back I get Horizontal lines or flicker? Is that from the frequency of the light? this is not a LED lit TV, but I guess one with fluorescent tubes?
Also, i had shot some night video of Neon signs in a bar window. I got a similar effect.
Is there a shutter setting, or anything to get clean footage? Or must i stay away from these types of light?
PS: is this caused by the flicker of the lights, or interference from the electronic ballast? It seemed to worsen the closet i got to the light source.
Thank you!
Max
Thank you!
Max
you answered your own question! :-)
ideal shutter would be 1/60 ...plays nice with our 60hz electricity.
Image basics: fluorescent lights produces pulsating light. Frequency in US is 60 Hz and 50Hz in EU. All shutter speeds faster than this values (1/50 and 1/60) produces flickers.
In addition, when there are some lamps of various fluos, this frequency could be double (with 2 fluos) or quadruple (4 fluos), because this lamps alternates between fluos they have.
And more: with fluo light, if you uses high speeds, it could produce color bands cause problems with white balance.
Byez to All
