davideo.net
I had loads of trouble getting a USB hard drive to work directly to the HPX300, so here is a step by step description. The manual says any USB 2.0 hard drive will work, as long as it's not 2TB or larger.
[FONT="]1. Push the menu button, go to “2. System Setup” (press the wheel in to accept)[/FONT]
[FONT="]2. PC Mode Select: USB HOST[/FONT]
[FONT="]3. Go down to the second page with the wheel and make sure PC MODE = ON[/FONT]
[FONT="]4. Plug in USB 2.0 hard drive (this will get formatted so make sure nothing important is on it)[/FONT]
[FONT="]5. Display changes to USB HOST – CONNECT[/FONT]
[FONT="]6. Now go to the menu under the rear door and press “thumbnail”[/FONT]
[FONT="]7. In the lower right the “USB HOST” will be yellow, and in upper right you will see “HDD” and a red dot – this means the hard drive is not formatted yet.[/FONT]
[FONT="]
[/FONT]
[FONT="]8. Press the “Menu” button at the lower right and click down to select “HDD” with the “set” button[/FONT]
[FONT="]
[/FONT]
[FONT="]9. Click “set” button at “Explore”
[/FONT]
[FONT="]
[/FONT]
[FONT="]10. You will see the hard drive display info, including brand and size. HDD Partition will say “Other”
[/FONT]
[FONT="]11. Here’s the part I screwed up several times = PRESS THE MENU BUTTON AT LOWER RIGHT
[/FONT]
[FONT="]12. Then Operation, then Format (HDD)
[/FONT]
[FONT="]13. Display will read “DELETE ALL DATA!” – click set button to “YES”[/FONT]
[FONT="]14. “SURE?” click YES
[/FONT]
[FONT="]15. Hard drive will format and you’ll be ready to transfer data! [/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[/FONT]
[FONT="]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
