Like above , how should I care of battery , is canon recommend anything to make them longer alive ?
Some people say , battery should be charged up to half if you do not use them for longer period time
I usually just charge my batteries to 100% and use them until they drain. I'll frequently leave one fully charged for extended periods of time -- sometimes many months -- without using it, and they continue to work fine. I've even had one particular battery since 2009. I used to use it on my XH-A1, and found it also worked on the C100, so I kept it and continued to use it. Still going strong 7 years later.
I have 5 canon genuine battery .3 battery got form amazon ( not from third party seller ) , 2 of them hold just only up to 60min at now . Another one when it is fully charge shows 240min , but after 10min of using shows just 120min . I do not know why is this happen , they are 1 years old , used maybe 30 times . I have to add that many times I leave them drain for longer time .
Ok I found some interesting things . Canon bp-955 are base on Lithium-ion.
They hold their charge. A lithium-ion battery pack loses only about 5 percent of its charge per month, compared to a 20 percent loss per month for NiMH batteries.
They have no memory effect, which means that you do not have to completely discharge them before recharging, as with some other battery chemistries.
Lithium-ion batteries can handle hundreds of charge/discharge cycles.
That is not to say that lithium-ion batteries are flawless. They have a few disadvantages as well:
They start degrading as soon as they leave the factory. They will only last two or three years from the date of manufacture whether you use them or not.
They are extremely sensitive to high temperatures. Heat causes lithium-ion battery packs to degrade much faster than they normally would.
If you completely discharge a lithium-ion battery, it is ruined.
A lithium-ion battery pack must have an on-board computer to manage the battery. This makes them even more expensive than they already are.
There is a small chance that, if a lithium-ion battery pack fails, it will burst into flame.
