Interesting article at LensRentals.com on the cost of repairs and how reliable different lens brands are...
Lensrentals Repair Data: 2012-2013
And the FS700 too: that ugly LCD-viewfinder design is not only unconfortable to use, also a weak point in terms of damage, it seems.
For a young crowd you are quite behind the timesI have three words for you- DRIVE BY WIRE
Yes, it does impact the size: the F mount has a 46.5mm flange focal distance (distance from mount to sensor), whereas canon EF is 44mm, so the Canon lens has to be 2.5mm longer if (as it happens) you want each piece of glass to sit at exactly the same distance from the sensor. All the difference between those two lenses should be between the last ring and the mount. Put them on a table, front-end-down, and compare?
