P Philip_38 Active member Oct 10, 2006 #1 I am starting a camara renting business in the Tampa, FL, area. How much would it be fair to rent my HVX's for?
David Jimerson Administrator Staff member Oct 10, 2006 #2 Have you checked to see what they rent for in your area?
Erik Olson Unscripted Mod Staff member Oct 10, 2006 #3 Between $450 - $550 a day with 3 cards and P2Store or FS100 is common right now in the NC. Doesn't include ancillary bits like tripod, extra monitors. You can always use the 20:1 rental-to-capex rule if a market survey isn't yielding enough data for you. e
P Philip_38 Active member Oct 10, 2006 #4 and what is "20:1 rental-to-capex " rule? Sorry for newbussiness
khmuse Tech Guru Oct 10, 2006 #5 Rental rate would be 1/20th of the capital expenditure (cost to acquire). Using this, if an item cost $1 then the rental would be $.05 To me this is a bit of a high ratio, but if the item is in demand and the local market will bear it, go for it.
