You would need a .6 ND to drop it two stops from f/5.6 to f/2.8.
Each .3 of ND is one stop.
From each f-stop to the next is one stop"
f: 1.0 1.4 2 2.8 4 5.6 8 11 16 22 32 45 64 90 128 180 256
ND .3 = 1 stop
ND .6 = 2 stops
ND .9 = 3 stops
Also if you're in a jam you can use a polarizer to gain a stop and a bit depending on the polarizer and brand.
Using ND filters is a great way to change your Depth of Field without changing your lighting between wide and close up shots - I frequently shoot my wides at f5.6 and close-ups at f2.8 (2 stops of light) so if you follow this technique just make sure you are lighting for f5.6![]()
Hi friends,
the other day I shot with on a 7d , ef-s 17-55mm f2.8 and CPL. 1080 24p , 50 shutter. I was only able to get good exposure at around 5.6 . if i wanted to shoot at 2.8 , how many stops of light ND should i get to add on? .9ND?
Thanks,
Chris
if you are at iso 400 or over than the answer can be none
So for example, I might establish a scene with wide, relatively flat lighting and high DOF to show what's going on and maybe some dialogue... then when we punch in for the big dramatic line, I can switch to more contrast, add backlight and really shallow DOF and it will look great... and no one will have a problem with it.
